Illustrator path tip
COW Forums : Boris FX Particle Illusion
Alan Lorence
on Jun 6, 2006 at 9:33:29 pm
I often get requests from people to add a feature to allow pIllusion to load Illustrator paths either for use as emitter motion paths, or to define the line emitter (or to allow particles to follow this path, but that's another issue).
Well, I just read about a trick that you can do with After Effects (if you have it) that allows you to use an Illustrator path as an emitter position path. I believe the steps are essentially:
1. Copy the path from Illustrator
2. Paste directly to position data in After Effects (spatial data)
3. Copy position data keys
4. Import position data via clipboard in pIllusion
I hope I didn't miss anything there.
Alan.
wondertouch
Aharon Rabinowitz
Re: Illustrator path tip
on Jun 7, 2006 at 6:17:39 pm
I cover steps 1 and 2 in a video tutorial you can find here:
http://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=23&page=...
The tutorial covers getting paths from Illustrator or photoshop into AE.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
