small bug report
COW Forums : Particle Illusion
Vincent
small bug report
on May 21, 2006 at 11:53:32 am
Hello,
Just to report a small bug: if you move a video file (used as background in a project) to an other folder when you open the poject PI crashes. A 'file not found' message would be better.
Just for the next version... i hope soon. Thanks.
Vincent
cowcow
Alan Lorence
Re: small bug report
on May 21, 2006 at 12:06:05 pm
What exact version number are you running (check the "About..." box) and what OS?
Alan.
wondertouch
vincent
on May 22, 2006 at 6:04:30 pm
Hello Alan,
I use PI 3.0 (3.0.1a 01/29/2004) on Windows platform.
Ps: As soon i replace file on its original place PI open my project.
Regards.
VINCENT
Jose Burgos
on May 23, 2006 at 1:49:53 pm
I do not have that problem with the same version of pi3.
What I get is a file window asking me where the file is to load it.
Jose Burgos
Trelawney
on May 24, 2006 at 3:19:27 am
Hi there
I've had this problem also - but mainly from when i've opened a IP3 by double-clicking on it to open.
If a texture/file is missing and I OK to search for it, when I select it in the file browser - PI3 just closes.
This doesn't seem to happen (as often) if I open PI3 first, then the IP3 file and then search for any files in the default location.
As an aside - I also get a Crash (Runtime error - abnormal program termination) in pIllusionRender if I select the AVI Options button. Does this happen to anyone else?
Kind regards
