COW Forums : Particle Illusion
on May 15, 2006 at 8:05:41 pm
I got Pilussion a few years ago, but a while back, whenever I tried to run it a message came up saying :Runtime Error! This program has requested runtime to terminate it in an unusual way. Please contact the applications support team for more info.
So I can't run it. Is there any way to fix this? Thanx
P.S. No errors come when I do an AVG scan
Alan Lorence
Re: corrupted
on May 15, 2006 at 9:03:26 pm
Use "reset default settings" in the Start - Programs - particleIllusion 3 menu. If that doesn't fix the problem, your default emitter library may be corrupted, so rename default.il3 to something else, then when pIllusion starts select a different emitter library.
© 2018 All Rights Reserved
