Bullet Effect
COW Forums : Particle Illusion
homers
Bullet Effect
on May 4, 2006 at 3:34:57 pm
Hi
Is there any way of me making a scene where you see the bullet in slow motion and the camera follows it, the bullet has a bullet trail effect just like they do in the Matrix?
Diony
Re: Bullet Effect
on May 4, 2006 at 7:57:50 pm
http://www.geocities.jp/ifurkend/bullet-time.zip
This effect requires 2 specific function of PI3 (byebye PI:SE), Super Emitter and Get color from background.
homers
Re: Bullet Effect
on May 4, 2006 at 9:04:01 pm
Diony, the bullet-time.zip when I open it there is nothing on the screen, the emmiters on it are Fire Blast which I don't have. Where do you get it? Thanks.
homers
Re: Bullet Effect
on May 4, 2006 at 9:07:44 pm
Alan Lorence
Re: Bullet Effect
on May 4, 2006 at 9:21:31 pm
Since it uses "get color from layer" for the particles, you need to load an image or movie or you won't see anything.
Alan.
wondertouch
Jose Burgos
Re: Bullet Effect
on May 4, 2006 at 7:58:02 pm
http://www.burgos-family.com/movies/joseburgos2003.wmv
The bullet was done in Lightwave.
All other was done in PI.
Rings emitter was modified to make the trail.
Jose Burgos
homers
Re: Bullet Effect
on May 4, 2006 at 9:30:17 pm
the effect still does not work, when I load it, it says the File E:/illusion3/bg.bmp was not found do you want to look for it YES/NO, if I click yes and open up a image it says " The images for Layer : Layer 0 has been removed" when it loads there is nothing on the screen even when i press play, it is the same if I click NO. Is there any other way of creating a bullet with the trail effects in slow motion?
Alan Lorence
Re: Bullet Effect
on May 4, 2006 at 9:38:13 pm
Load your own image. Sounds like you need to study this page a little:
http://www.wondertouch.com/quickstart.asp
Alan.
wondertouch
homers
Re: Bullet Effect
on May 5, 2006 at 3:29:29 pm
Hi
Got it to work but that is only a bullet trail, it's cool, but is there any way of me getting a bullet aswell?
Aharon Rabinowitz
Re: Bullet Effect
on May 5, 2006 at 11:42:35 pm
If you use after effects, I cover this effect in my Creative Cow Master Series DVD, particleIllusion Fusion - Volume 1.
http://www.creativecowtraining.net
I basically use particles along with diplacement maps.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
Aharon Rabinowitz
Re: Bullet Effect
on May 5, 2006 at 11:44:39 pm
Forgot to mention, if you watch my tutorials on diplacement maps (just click on my head to go there) they will give you an idea of how displacement works - I think this will really help you.
Aharon Rabinowitz
