COW Forums : Particle Illusion
on May 2, 2006 at 7:54:19 pm
Can I make a really realistic metoer come hurtling down from the sky making a explosion hitting the ground? Also when I download emmiters and put them in the Emmiter Libary they are lot there when I load the program, how can I get them?
Alan Lorence
Re: meteor
on May 3, 2006 at 10:49:40 pm
There are several "smoke trail" emitters that can be used for meteor trails, and there are several explosions too.
R-click in the library window and select "load library" then select the library you want. In 3.0, use the "quick-load" list too.
© 2018 All Rights Reserved
