Hold Frame
COW Forums : Particle Illusion
Chortorn
Hold Frame
on Apr 26, 2006 at 11:00:55 pm
Is it possible to make an animation of imported png's stop at the last frame? Or should I make a workaround by added 100 of the same frame in the end?
It could be nice to be able to control animation speed over life.
Thanks in advance
Chortorn
Elvis Deane
Re: Hold Frame
on Apr 27, 2006 at 2:07:05 am
In the Background Image options, make sure that the Hold Last Frame box is checked. If the box beside that is set to 0, it'll hold forever, but you can change that as you need.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
Chortorn
Re: Hold Frame
on Apr 27, 2006 at 5:16:06 am
I was tired when I wrote it. I meant with particles. Is it possible to make an animated particle stop at the last frame? I.e. flowers growing, branches growing, etc.
Chortorn
Elvis Deane
Re: Hold Frame
on Apr 27, 2006 at 5:30:57 am
If you animate the Number graph down to 0, that would stop new particles from being created. Though if they are moving, it won't stop them in their place.
Elvis Deane!
Alan Lorence
Re: Hold Frame
on Apr 27, 2006 at 11:52:38 am
The only thing you can do is adjust the "life" property so that the particles die at the end of the sequence.
New particle shape sequence options are planned for 3.5, so this will be possible without having to tweak the life.
Alan.
wondertouch
Chortorn
Re: Hold Frame
on Apr 28, 2006 at 11:22:28 am
I have solved it with a workaround - animationspeed changes and stops. However the animation has to be made precisely for this method.
Should I upload the file?
Chortorn
