CPU usage is on 50% after PI is running
COW Forums : particle Illusion
dotan
on Apr 22, 2006 at 3:34:10 pm
HI
i have a dual amd processor and 2GB ram
after i open PI3 i see the cpu is on 50% same with AE
any idea how to fix it without installing windows again?
Alan Lorence
Re: CPU usage is on 50% after PI is running
on Apr 25, 2006 at 11:25:23 pm
I'm not sure it's a problem. On my laptop, pIllusion uses 90%+ cpu when the
preview is animating a complex super emitter. If the preview window isn't
doing anything, it uses 0%. Simple emitters use less cpu % (some are only
5% or so).
So a dual cpu machine would max out at 50% since it's only using a single
cpu (as I understand it).
I wouldn't reinstall Windows.
Alan.
wondertouch
