Crashes with librairies management.
COW Forums : Particle Illusion
VINCENT
on Apr 15, 2006 at 12:46:05 pm
Hello to all,
i'm new with PI i bought just today after tried the demo. Here is my problem : Sometimes in librairies management PI crashes with a windows message error wich close the PI application.
Is it a known problem? is there something special to do ?
Thanks in advance for help.
VINCENT
Elvis Deane
Re: Crashes with librairies management.
on Apr 16, 2006 at 4:31:49 am
It's not a problem that I know of, and I've used the manager quite a bit. Is it when you do a specific task in the manager, or does it just happen at random times?
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
Vincent
on Apr 16, 2006 at 12:41:24 pm
Hello, I had repetitive error renaming the last folder after deleting all folder of the library to create a new empty library, i took a downloaded library, then i did the same thing but starting from default library and now i have no problem.
thanks for your attention.
VINCENT
vincent
on Apr 19, 2006 at 6:28:46 am
Hi Elvis,
I know why i have some crashes in library manager, it's due to a reference to an old library folder (from the DEMO).
Because demo uninstall program doesn't remove PI root folder when i have installed full version it keeps reference to demo folder, and because i have deleted manualy demo folder that produces crashes because the folder doesn't exist.
I solved my problem removing a key in register (library path).
VINCENT
