TumbleWeeds
COW Forums : particle Illusion
Jonathan L
TumbleWeeds
on Mar 27, 2006 at 4:19:12 pm
I need to create some tumbleweeds and I was wondering if I could get some tips? I'm not sure I have a good enough handle on the physics of PI to create convincing motion. Any ideas would be greatly appreciated.
Jon
Elvis Deane
Re: TumbleWeeds
on Mar 27, 2006 at 7:42:56 pm
I think the key would be to give it a pretty high velocity, and a bit of Weight, but also to increase the Bounce factor by a bit. That way it'll bounce up by itself if you use a Deflector as the ground object.
I'll see if I can post an example emitter a little later. Seems like a fun effect to try, and a good reason to sing the Tumbling Tumbleweeds song over and over.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
Jonathan L
Re: TumbleWeeds
on Mar 28, 2006 at 2:25:43 pm
Thanks I'll give it a try, I didn't even think of adding a ground object.
Jon
