changing immiters
COW Forums : particle Illusion
stevewhite
changing immiters
on Mar 24, 2006 at 4:35:54 pm
once a animation has been created in pi3 whats the easy way to change the immiter for another one without redrawing the animation? any help whould be most welcome.
Jim
Re: changing immiters
by
on Mar 24, 2006 at 5:41:53 pm
See the PI Help files, Tutorial 4 - Replacing an Emitter:
First, select the library emitter that will replace the stage emitter. Then R-click on the stage emitter and select Replace. You'll be asked to confirm the replacement:
After clicking Yes, you'll see the Replace Emitter Options dialog which allows you to determine which stage emitter properties to save, and which to replace with the library emitter properties.
Checked properties will preserve the values from the existing stage emitter, unchecked ones will use the property values from the library emitter.
stevewhite
on Mar 24, 2006 at 9:57:47 pm
sust this right clich emmiter and goto export position data to save your data as a text file then add a new emmiter to the stage and import back your emmiter file............thanks anyway.
