Light- shadow effect ...
COW Forums : Particle Illusion
dennis
on Mar 15, 2006 at 12:04:51 am
Hi there.
I
Adrian808
Re: Light- shadow effect ...
on Mar 15, 2006 at 2:13:07 am
Particle Iullsion could make a Glow, but in order to make those light rays FX try a Compositing program such as Premiere, Vegas, or Ulead Movie Studio... I personally make this FX in Sony Vegas, in the VFX Section... the FX is called Light Rays.
PD: If you combine your compositing program's VFX with particle illusion's FX you could create interesting creations (by placing an FX rendered in black background over the video on an extra layer, the in the "add" mode)
shadu
on Mar 15, 2006 at 2:33:51 am
This effect was made with the trapcode plugin Shine. A very good plugin for after effect and combustion. I don't hink you can do it in PI.
Shadu
Alan Lorence
on Mar 15, 2006 at 1:41:50 pm
I agree that it's not an effect that particleIllusion can do. You might be able to get a "rays of light" effect, but you could not make it move across the screen.
Alan.
wondertouch
Dennis
on Mar 15, 2006 at 2:03:17 pm
So i need another composing programm.
Thank you all!
Dennis.
Aharon Rabinowitz
on Mar 15, 2006 at 10:52:25 pm
Yeah - shine is definately the plugin to use for this sort of thing.
However if you have AE, you may want to try CC lightzoom also - not nearly as nice though.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
Unzarjones
on Mar 16, 2006 at 1:04:30 am
Mirage has a volumetric effect that is very polished. Certainly not a product to buy just for that unless you also print your own money. Boris does it too. UJ
Greg Paterson
on Mar 16, 2006 at 3:53:50 am
I did this many years ago using Animation Shop which was a part of Paint Shop Pro V7. This is a built in preset.
I made a few varaints and then layered them.
As said by others, this could then be brought back into PI and tarted up a bit more to your taste.
http://www.teliocide.com
http://www.3D_Icthyomania.com
http://www.croc_swamp_fishing.com
http://www.tropical_carp.com
Alan Lorence
on Mar 16, 2006 at 12:32:34 pm
What would bringing it into pIllusion do if you've already created the animated light effect in Animation Shop?
Alan.
wondertouch
Greg Paterson
on Mar 16, 2006 at 2:18:46 pm
Probably not anything to the light rays.
You could put a flash/pulse of light behind the letters in time with the brightest ray emmission, or run a fine line of sparkles around each letter as the stongest ray is emmited.
