Bullets hitting the ground
COW Forums : Boris FX Particle Illusion
choc_tpot
on Mar 14, 2006 at 4:59:34 pm
Im trying to achieve the effect of bullets hitting the ground. You know like when a helicopter flies over and its machine guns are shooting at the ground and you see the dust thrown straight up. Anyone know how I can do that?
Im also trying to achieve the same effect on a larger scale, to give the impression of a huge projectile smashing into the desert.
Jose Burgos
Re: Bullets hitting the ground
on Mar 15, 2006 at 4:40:51 am
Play with the dust puff emmiter.
Take care,
Jose Burgos
Elvis Deane
on Mar 15, 2006 at 5:28:56 am
There are two that do exactly this sort of thing in one of the Eclectic pro-emitter libraries, but if you don't have those you can probably use Boom 5 from the June 2003 library for the larger impact, and with a little editing it can probably do bullet hits as well.
There's also a few Rain Splash emitters in the May 2005 library that would probably work quite well if you convert them to a point emitter and animate their position. It might not be as dramatic an effect as you're looking for though.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
