Can I delete the backup files?
COW Forums : particle Illusion
mandyy
on Mar 13, 2006 at 7:29:38 pm
I found this file, duplicate and backup, can I delete it safely?
107cancel35.il3_00000.bak
Aharon Rabinowitz
Re: Can I delete the backup files?
on Mar 13, 2006 at 11:23:20 pm
I want to let Alan chime in here, but deleting your backup emitter files will not effect anything. In fact, if you frequently make changes to your libraries, you may want to regularly go though and delete these things, as they start to pile up.
So if you erase them you should be fine.
Elvis posted some info on this a while back thaty may be helpful:
http://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=23&postid=8...
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
