Ground explosion
COW Forums : Boris FX Particle Illusion
Shadu
Ground explosion
on Mar 10, 2006 at 10:54:42 am
Anyone know was made the ground explosion as see in the pro emitter eclectic 2 package?
I try to figure it out.
Shadu
Alan Lorence
Re: Ground explosion
on Mar 10, 2006 at 12:31:19 pm
The way to analyze an emitter is pretty simple. Start at the top of the hierarchy and select each property one at a time, and look at the graph. Any graph that is animated (has more than one data point) should be experimented with to see what it does to the overall effect.
Most of the "magic" happens in the particle type "over life" properties.
Also look at the particle shape images used for each particle type.
Alan.
wondertouch
shadu
on Mar 10, 2006 at 3:24:06 pm
Thanks.. The only problem is a need to buy it to analyse it.
Shadu
Unzarjones
on Mar 10, 2006 at 5:25:37 pm
LOL!
