PI problem with pictures and effects :(
COW Forums : Particle Illusion
Mythos
on Mar 3, 2006 at 9:11:27 am
Hi Wondertouch Team , ive got a problem about pictures and effects.
Ive made a simple animation with a picture wich fade out the opacity , in after effects , than import the xvid file into PI , all fine.
When i put a effect over this animation , maybee a waterfall or something else ,
in the prgramm it will be worked but when i render it , it looks like behind the animation:( only a little bit of the effect i can see on the sides :(.
Whats wrong , can u tell me how i can get this effect over the animation ?
I
Elvis Deane
Re: PI problem with pictures and effects :(
on Mar 5, 2006 at 11:16:58 pm
I'm really not sure what would be causing this. Do the particles render okay if you don't have a backgrond image?
If so, then I suggest that you try hiding the background, rendering the particles as an image sequence with an alpha channel, and then importing that into AE and compositing it over the original fading picture.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
