Particle Illusion in After effects 7 ?
COW Forums : Particle Illusion
Rafael750
on Feb 13, 2006 at 7:53:50 pm
Particle Illusion don't work with After Effects 7 ?????
When I import clipboard, i see error message !
I try copy clipboard (position frame) to "tab-delimited Text (from file)" but position not correspond in after effects 7 ,,
Do you have some secret to this ? I use Windows XP !
Rafael750@yahoo.com.br
Brasilia-Brazil
Alan Lorence
Re: Particle Illusion in After effects 7 ?
on Feb 13, 2006 at 9:41:07 pm
There was a slight change in the data format from AE 6.5 to AE 7.0. I suggest copying the data to a text file, then deleting every line except the lines that contain the position data. Each line should be in the format:
Frame_number X_pos Y_pos
Then you should be able to load it into pI3.
Alan.
wondertouch
Rafael750
on Feb 13, 2006 at 11:17:35 pm
Oh thanks !
Jeff Bellune
on Feb 14, 2006 at 3:35:45 am
Hi Alan,
I know you are working on the plug-in for AE and I have read a few topics here in the forum about that plug-in. I have 2 questions:
1. Will the plug-in for AE, when released, be compatible with AE7?
2. Will there be an update to the pI stand-alone version 3 that will properly import keyframe information from AE7 via the clipboard?
-Jeff
Alan Lorence
on Feb 14, 2006 at 1:16:53 pm
Yes to both.
Alan.
wondertouch
