More smoke
COW Forums : Particle Illusion
Burlapmaster
More smoke
on Feb 3, 2006 at 3:47:34 am
Hi
I had a man breathing out smoke. I used the shoot smoke emitter and set emission angle so it would come out of his mouth sideways. I then wanted it to float up as it faded away. However, when I changed the weight setting, it just made the smoke go faster in the direction it was already heading. Is there a way to make it float up after shooting out to the side?
thanks.
Alan Lorence
Re: More smoke
on Feb 3, 2006 at 12:36:42 pm
Make the particle type weight value negative -- something like -20. You'll see the smoke move up. (Negative weight values mean lighter, positive values mean heavier)
Alan.
wondertouch
Aharon Rabinowitz
Re: More smoke
on Feb 5, 2006 at 1:08:07 am
plus you may want to play with it's weight over life property, so that it has no weight at first, and then gets heavier and floats up a little later. Not being a smoker, I can't say that this is exactly realistic, but I think it is - first, as smoke is breathed out it shoots out, and then it disipates as it rises.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
