Aharon, got a question for you.....
COW Forums : Particle Illusion
Gene Patrick
on Feb 2, 2006 at 9:35:35 pm
Hi Aharon,
I purchased your tutorial DVD, which is GREAT!, learned a lot from it. I am wondering if you can answer a question for me. I created a logo in PS, then created a work path outlining the logo. I then copy and pasted that into a solid in AE. I then turned that mask into a motion path and copy and pated the keyframe position data into PI3. The problem is that I'd like to change the starting and ending points of the motion path. Any ideas on how I can do this? Thanks for your help in advance and when can we expect a follow up to your PI3 DVD?
Best regards,
Gene M, Patrick
DIRECTV
Aharon Rabinowitz
Re: Aharon, got a question for you.....
on Feb 3, 2006 at 4:07:45 am
Yes. In AE You need to select the mask, and then the point you want to be the beginning and choose Layer > Mask > Set first Vertex point. (also Right clicking on the point will bring up the same option).
This sets the first point of the mask, which should solve your problem.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
Gene Patrick
on Feb 3, 2006 at 9:52:42 pm
Thanks Much, I appreciate the help. I am wondering if you'll be doing a follow up to your PI DVD? If so, it'll definately be on my list to get. Thanks again.
Gene M. Patrick
Aharon Rabinowitz
on Feb 5, 2006 at 12:51:00 am
I'm hoping to. A lot depends on sales, but that's my goal.
Thanks for your interest. Good luck with everything!
Aharon
Aharon Rabinowitz
