How to extend the life of a logo?
COW Forums : Boris FX Particle Illusion
ljCharlie
on Jan 29, 2006 at 2:53:09 am
I am using the Ring Converge logo. The problem I have is that the logo disapear after frame 110. How do I keep the logo appear longer? For example, after the logo appears I want the logo to stay like 4 seconds then shrink back. How do I achieve this? Thanks in advance.
Elvis Deane
Re: How to extend the life of a logo?
on Jan 29, 2006 at 5:35:33 am
The simplest way to do it is to copy and paste a new version of the logo at frame 1. Right-click on it in the stage and convert it to a point emitter. Now the particles will just fly up instead of coming in from all sides. Reduce the Velocity graph to 0, and crank up the Life to about 200%.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
ljCharlie
on Jan 29, 2006 at 6:00:18 am
Thanks. I'll give that a try.
ljCharlie
on Jan 29, 2006 at 6:14:51 am
Well, I gave it a try...it does extend to about 10 or 20 frames but not long enough. Anyway to make it longer?
Elvis Deane
on Jan 29, 2006 at 6:24:36 am
The more you increase the Life graph, the longer the particles will stay on the stage. So just push that past 200, until you get the length you need.
You'll have to make two more changes if you push it much more than 200%. In the duplicate emitter you made, reset the Size over Life graph, and increase the topmost Size graph to 200%.
Elvis Deane!
ljCharlie
on Jan 29, 2006 at 7:00:08 am
Thanks! Gonna try again.
ljCharlie
on Jan 30, 2006 at 1:38:31 am
Thanks! That works for now.
