Text in the Matrix Falls Effect
COW Forums : Particle Illusion
jez
by
on Jan 25, 2006 at 1:29:38 pm
Is there any way to add text to the "Matrix Falls" effect given in the Default libary?
Would be great if you could hlep me, thanks
Jeremy
Alan Lorence
Re: Text in the Matrix Falls Effect
on Jan 25, 2006 at 4:35:33 pm
EVERY particleIllusion effect uses images for the particles. To change the letters, words, etc., you just need to change the images that are used.
Check the docs under "change shape", check the pIllusion FAQ:
http://www.shockingtales.com/illusion/faq.html
Also check out these tutorials:
http://www.kolumbus.fi/erkki.halkka/Tutorials/Illusion_01/Boom01.html
http://www.wondertouch.com/tutorials/frog/frog.htm
Alan.
wondertouch
