Mixing Emitters
COW Forums : Boris FX Particle Illusion
adrian808
Mixing Emitters
on Jan 22, 2006 at 1:38:22 am
It is possible to grab for example a sparkle emitter with a fire emitter individually and combine the two of them to make ONE emitter? or you have to do all those things in the proyect window?
Alan Lorence
Re: Mixing Emitters
on Jan 22, 2006 at 5:32:43 pm
Open the properties dialog for the library that contains both emitters. Then in the hierarchy of the properties dialog, drag the particle type from one emitter into the other emitter.
Note that the results may not be exactly what you expect, since the emitter properties (which act as a scale factor) are probably different for both emitters.
Alan.
wondertouch
