Double AVI encoding twice!
COW Forums : Boris FX Particle Illusion
jamesinnewcastle
on Jan 19, 2006 at 2:34:19 am
I have an animation done in Cinema 4D - this was made into an avi file using a codec (irrelevant which)
I then add some Particle Illusions with the avi as the background image and then output the result as an avi file using the same codec. All looks great in the editor
So I have therefore used the codec twice over and get a corresponding loss in quality, not in the particles but in the background avi.
So how is this problem avaoided by the professionals?? Must the first avi be uncompressed for example? Can anyone help, this must be a common problem.
James
Aharon Rabinowitz
Re: Double AVI encoding twice!
on Jan 19, 2006 at 2:41:19 am
we don't work with compressed video at all. The only point at which we compress is the final render - meaning of we are putting the video on the web or CD. If it's going to broadcast, generlaly speaking, there is no compression done.
There is one exception - certain video cards or programs have proprietary video codecs that are lossless but very tight. In those cases, you can compress with no real loss - however, only poeple with those programs or hardware can see the videos. That's why, in the final render, you depart from using that codec, and render uncompressed (or in a compression format people can see on the web, if that's your target).
That said, I'll ask people here to sound off about their favorite codecs for keeping the quality up. I've heard that Huffy is apretty good one for nearly lossless quality, plus DivX is pretty good. Not totally pro, but for good quality, it's a decent solution for your interim renders.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
jamesinnewcastle
on Jan 19, 2006 at 3:10:00 am
So, should I infer that the background avi should be uncompressed?
If so it will be a big file - won't that slow PI down to a crawl as it tries to manipulate the fields? I've not checked recently but I do remember using a big background avi once and it took ages to move the frame count up and down.
James
PS would like to know what the popular Codecs are!
Aharon Rabinowitz
on Jan 19, 2006 at 5:04:42 am
you might consider using a compressed video in the BG for preview purposes and then swapping it out for final render - if you are compositing in pIllusion.
You could also render an image sequence (Like Tiff TGA, PNG) from your 3D app. pIllusion can read those.
Also, you could composite your 3D and 2D in a compositing program like After Effects.
Again, in answer to your question, most pros wouldn't do their compositing directly in pIllusion because it's not a great program for that - it does a good job on a basic composite, but for anything more complicated then dropping particles on a BG layer, you start to get diminishing returns - it can do it, but it get's more difficult and isn't as flexible as programs designed to do compositing, or even an NLE that can use particle rendered as, say for example, TIFF with Alpha.
I'll tell you what I tell all of my students when they ask why they need to buy a big harddrive: Video and Animation requires a lot of space if it's to be done right. I have 750 Gigs of external space, and I always want to buy more... That said, You can always erase the big renderes once you do your final render. So you can do OK with even a single 250 GB drive. they aren't that expensive.
Aharon Rabinowitz
jamesinnewcastle
on Jan 19, 2006 at 6:41:59 pm
Thanks Aharon
Makes sense now! I shall output from both applications as say tiffs and only generate the avi from the program that combines the two. From that I can choose exactly the codecs I want.
James
