Ground explosions
COW Forums : Boris FX Particle Illusion
BurlapMaster
Ground explosions
on Jan 18, 2006 at 4:42:51 am
Hi
I've got SE and I was wondering how to make an explosion go in one direction instead of just a bird's eye view. For example, an explosion on the ground in the distance.
EVideoM
Re: Ground explosions
on Jan 19, 2006 at 12:01:55 am
Put your emitter on the screen, right click it anc choose circle or ellipse. That will give you the effect I think you are looking for, you will probably still have to mess around with some of the other functions to perfect the look. Zoom is also another setting to use.
Alan Lorence
on Jan 19, 2006 at 12:29:38 am
Also, decrease the emission angle from 360 to 90 or less, then adjust the angle to 90 (for straight up).
Alan.
