How to make curved lines with emitter shape ?
COW Forums : Boris FX Particle Illusion
Papain
on Jan 9, 2006 at 8:29:57 pm
Hi all !
I was wondering is there is a way to make curved lines with emitter
shape...?
Thank You.
Papain
Elvis Deane
Re: How to make curved lines with emitter shape ?
on Jan 10, 2006 at 12:33:01 am
Line emitters can only be straight, you'd have to add a number of points to curve the line.
You can also draw a curved line in a paint program, save it as a TIF or TGA with an alpha channel, and use it to birth particles using Area Emitter Masks. But the advantage of a line emitter over that method is that the emission angle of the particles will be determined partly by the angle of each segment.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Papain
on Jan 10, 2006 at 9:13:57 am
Thank You for your answer ! Maybe with the next version.... ;-)
