Alpha Channel
COW Forums : Particle Illusion
Adrian808
Alpha Channel
on Jan 4, 2006 at 3:48:56 am
I know you could make great things with images or videos rendered in alpha channel, but I don
Aharon Rabinowitz
Re: Alpha Channel
on Jan 4, 2006 at 7:10:54 pm
Can you please explain what exactly you are trying to do - even if it's just an example - so it's a little more clear.
Thanks.
Aharon
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
EVideoM
Re: Alpha Channel
on Jan 15, 2006 at 9:41:43 pm
I am trying to mask/block emitters in Vegas 6.0 but for some reason as soon as I try to use the mask featue the emitter disappears. I tried to render in alpha but the option is not available, is that because I have the trial version of PI? If so, if I decide to buy PI will rendering in alpha solve the problem of the disappearing emmiter when trying to mask in Vegas?
