Growing Vines
COW Forums : Boris FX Particle Illusion
Adrian808
Growing Vines
on Dec 14, 2005 at 1:28:13 am
In wondertouch's start page there is an emitter called Jungle that simulates growing vines.. I can
Elvis Deane
Re: Growing Vines
on Dec 14, 2005 at 4:45:48 am
The July 2003 has the vines emitter, in the Eki Halkka folder. Make sure that you turn on Don't Erase in the Project Settings. Otherwise, it'll just look like a bunch of blips moving around.
You can edit the shapes of the leaves by editing the Size over Life of the bottom particle type.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Adrian808
Re: Growing Vines
on Dec 14, 2005 at 6:24:04 am
Ok! i found the folder.. but I only get to see the leaves.. the vines are not visible..
I went to the proyect settings.. and I checked the box that said Dont Erase.. What could be wrong?
PD: Thanks in advance
Alan Lorence
Re: Growing Vines
on Dec 14, 2005 at 3:22:46 pm
They both work for me -- make the emitter line longer and let the project go longer than 120 frames. You'll see the vines.
Alan.
wondertouch
Adrian808
Re: Growing Vines
on Dec 14, 2005 at 10:44:29 pm
Hey Thanks bro!.. now I figred out the purpose of that "dont erase" checkbox! heheh .. REally ingenius emitter!!
Aharon Rabinowitz
Re: Growing Vines
on Dec 15, 2005 at 3:57:30 am
you won;t see anything until you actually hit "Play." ANd if you start later in the timeline, it will only draw from that frame forward in time.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
