Path with Particle Illusion
COW Forums : Particle Illusion
Plugman
on Dec 5, 2005 at 6:51:17 pm
Hi everybody,
This is my first thread on this excellent forum.
I want to know if it's possible to follow particules on a (vector ?) path ?
Thank you.
Plugman
Aharon Rabinowitz
Re: Path with Particle Illusion
on Dec 6, 2005 at 3:39:22 am
The particles cannot follow a path. Once they are released from the emitter, the move about freely, and can only be indirectly controlled through forces and defelctors.
Emitters (The thing that emits particles can follow a path you create in pIllusion (by setting up position keyframes), by importing a motion path from After Effects clipboard, or by importing a tab delimited text file generated via one of the plug-ins found at wondertouch's website - usually a 3D programe exporting position keyframes through a plug-in).
In short (sorry for all of that) neither the particles nor the emitter can follow a vector path (such as an illustrator path) at this time.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
