PI Won
COW Forums : Boris FX Particle Illusion
Khrysller
PI Won
on Dec 2, 2005 at 4:16:40 am
Hi...
Weird... i was using PI 3 weaks ago.. then today... it
Elvis Deane
Re: PI Won
on Dec 2, 2005 at 11:57:22 am
Under the pI start menu group, select "reset default settings" if its there.
If not, I think you can reset it by running "particleIllusion.exe -reset" from the command line.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Alan Lorence
Re: PI Won
on Dec 2, 2005 at 7:19:44 pm
If you don't have "reset default settings" in your start menu -- probably means you didn't use the installer, which probably means you don't have a legal copy.
You can also pass a "-reset" parameter on the command line.
Alan.
wondertouch
Khrysller
Re: PI Won
on Dec 3, 2005 at 10:40:32 pm
thanks you type the 'probably' word...
i clean up my start menu as I can AND i let just the app.exe and delete others shortcuts...
...again.. thanks you type the probably word...
Khrysller
