What is the best export format please before either After Effects, Sorenson Squeeze or Flash Video encoder?
COW Forums : Particle Illusion
Grant Barker
on Nov 30, 2005 at 2:51:48 am
So I would use maybe Sorenson Squeeze or the latest Flash Video Encoder to make an FLV, but I would like to make sure I am exporting with the best options for my projects.
Thanks for the headsup.
Grant
http://www.grantbarker.com
Alan Lorence
Re: What is the best export format please before either After Effects, Sorenson Squeeze or Flash Video encoder?
on Nov 30, 2005 at 1:04:48 pm
The best format to render in pIllusion if you plan on bringing it into another application for further processing (such as After Effects) is to save in a lossless format. Neither Sorenson nor Flash Video is lossless (I believe). You're better using the Animation QuickTime codec, or the Hhuuf UV codec, or saving as a TGA or PNG sequence.
Alan.
wondertouch
Grant Barker
on Nov 30, 2005 at 2:38:20 pm
Thanks Alan.
I'll have a play around.
Grant.
