how would I do this?
COW Forums : Boris FX Particle Illusion
rinny8
on Nov 25, 2005 at 3:45:16 pm
I want an effect to circle around someone. How would I make it so that the effect (say an orb) goes behind the person on one side, comes back on the other side and goes in front of them? I can't use the blockers cause they block it no matter what.
Alan Lorence
Re: how would I do this?
on Nov 25, 2005 at 3:50:16 pm
http://www.wondertouch.com/tutorials/around_01/around.htm
If you don't have the person masked out (with an alpha channel), you can still use blockers. Just put the "front" emitter on a different layer.
Alan.
wondertouch
rinny8
on Nov 25, 2005 at 4:36:48 pm
thanks
Grant Barker
on Nov 30, 2005 at 3:38:37 am
Also, if you have Adobe After Effects, you can split the layer. (at the point where you want to seperate the infront and behind parts).
