Are there any good mushroom cloud explosions out there?
COW Forums : Particle Illusion
rinny8
on Nov 22, 2005 at 12:30:37 am
I'm trying to show a city blow up in a huge atomic explosion! : )
rinny8
Re: Are there any good mushroom cloud explosions out there?
on Nov 22, 2005 at 12:32:02 am
oh...and one more thing. Is there anyway to make particles climb up walls and stuff? Say like having cracks run up a wall or a wall rotting away or something. I saw something like this on the Wondertouch website but I think it was proffesional...
Elvis Deane
on Nov 22, 2005 at 7:47:03 pm
There are a bunch of mushroom clouds in the July 2004 library.
The best example I've seen of rotting/cracking type effect is the clip from Smallville on the pI demo reel (the hand placing the dis)
I think that was done by using an emitter as a displacement or bump map in a 3D program. Super emitters with high f-Velocity, long particle Life, and low particle velocity should be able to create a nice growing crack effect that you can then map onto 3D geometry
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Alan Lorence
on Nov 22, 2005 at 7:55:52 pm
[Elvis Deane] "I think that was done by using an emitter as a displacement or bump map in a 3D program"
I believe the "don't erase" option was used as well, so the particles "draw" the cracks.
Alan.
wondertouch
rinny8
on Nov 22, 2005 at 9:06:36 pm
unfortunatley I 'm not a 3D person...
rinny8
on Nov 22, 2005 at 9:07:16 pm
oh well thanks for the library!
Elvis Deane
on Nov 22, 2005 at 9:32:57 pm
A lot of compositing and editing programs have bump/displacement filters that can get similar effects to a 3D displacement map. Have a look at whatever software you use.
Elvis Deane!
rinny8
on Nov 22, 2005 at 9:42:41 pm
ok thanks!
