how can i make brakeing glass fx
COW Forums : Particle Illusion
tony
by
on Oct 24, 2005 at 5:05:58 pm
hi
is there away to make the fx of breaking glass
or shattering fx of glass
can i use footage of glass and break it can i take alittle bit of that footage and turn it into emitter fx ?
thank you for your time
Aharon Rabinowitz
Re: how can i make brakeing glass fx
on Oct 24, 2005 at 6:09:10 pm
In the August 2003 Library (I think) there is a glass shatter emitter which could help add to the effect.
http://www.wondertouch.com/downloads/new_libs/emitters_03_08_il3.zip
Also, if you want to do it yourself, here are some looping debris sequences I made a while back. If you use them as the emitter shape for one of your emitters, it may help:
http://www.allbetsareoff.com/pIllusion/Debris_Sequences.zip
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
tony
by
on Oct 24, 2005 at 8:07:42 pm
thank you so much :)
