water wake
COW Forums : Boris FX Particle Illusion
byronregpi
water wake
on Oct 19, 2005 at 12:51:16 pm
hello again sorry HI everyone how can i add for Attachments post for picture how?? can i add for that ?? just show something
Alan Lorence
Re: water wake
on Oct 19, 2005 at 1:15:11 pm
You can't add attachments to a post, but you can include references to files on a server. So if you can upload your files somewhere, you can include a link to them in the post.
You can also embed an image into a post, but again it's just a reference to an image file on a server somewhere else. For instance, if you have found an image of an explosion that you want to show people, you can embed it here:
To do this, copy the image address, then click the little camera icon above (between the "U" and "L" icons), then paste the image address in.
Alan.
wondertouch
byronregpi
Re: water wake Website
on Oct 19, 2005 at 4:39:37 pm
anyway i try that use i give up i use just website ok you can look that what look like i want make special effects i want know what kind of that for final cut pro or visual effects or what i need want know because i want use that for film effects
like front and side either wantknow how use that make effect do have any
you can look that website
http://www.photographyblog.com/gallery/data/3120/1233WATER_WAKE_OF_BOAT_BXW...
http://www.nps.gov/yell/slidefile/water/lakesponds/yellowstonelake/Images/0...
Elvis Deane
on Oct 20, 2005 at 7:43:54 pm
Here's a REALLY quick test that I made of that sort of effect. This does use a pI3 only feature (where you can specify each particle type's emission angle and range), but you could still recreate it in pISE using 3 emitters instead of one.
http://pi.shockingtales.com/videos/boatWake01.avi
I have to run to a class now, but I can try to write some instructions when I return.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
byronregpi
on Oct 21, 2005 at 12:36:10 pm
ok that http://pi.shockingtales.com/videos/boatWake01.avi not work did wait loading might longer i am understand i can wait for you ok anyway
Elvis Deane
on Oct 24, 2005 at 9:11:20 am
You need DIVX 5 installed to be able to view that clip.
Elvis Deane!
byronregpi
DIVX 5
on Oct 24, 2005 at 12:21:44 pm
i finish install download finish then what next ??? what i need do with that before i send http://pi.shockingtales.com/videos/boatWake01.avi that what me need do with that ?? because i try put where how please explain thank you
byronregpi
Background
on Oct 24, 2005 at 5:49:19 pm
Hi want know any Emitter library load different effect have Words etc i want know how can make background behind person for example bomb or fire or any for example when stand behind fire on house how can person stand front and behind house fire cover or water whatever how but i have only particleIllusion SE i dont have 3.0 not yet
Elvis Deane
Re: Background
on Oct 24, 2005 at 9:17:05 pm
If you have a compositing program like After Effects or Combustion, you can create masks in that, and then render out your effects in pI and place them behind the layer with your actor on it.
Wax from Debugmode ( http://www.debugmode.com/wax/ ) is a free compositing program that lets you draw masks around people and animate them if you don't have any other compositor. I haven't used it in a few versions, so I don't know how good the masking is (the feature you're looking for is called RotoMate), but it might do the job for you.
Elvis Deane!
byronregpi
Re: Background
on Oct 24, 2005 at 11:56:56 pm
i was download that wax it very cool but one thing problemi have only WXP not have AVI or MPEG ETChow add with wax ( http://www.debugmode.com/wax/
Elvis Deane
Re: Background
on Oct 25, 2005 at 2:30:49 am
If you go to Project>Add Media File, then you can bring in AVIs or other videos.
Elvis Deane!
cow
byronregpi
Re: http://www.wondertouch.com/uses05.asp
on Oct 25, 2005 at 4:07:28 pm
this http://www.wondertouch.com/uses05.asp i notice that one last bottomn next one when has shoot to man then disappear that how make that do mean use first on Chroma key green or blue use that or normal in house or anywahere but how when shoot to person it disppear how? use with picture backgroud or what i want learn how use that but i know same i have only particleIllusion SE oh well but point i need want how you make that when shoot camera finsih then load to wondertouch make use that http://www.creativecow.net/articles/deane_elvis/logoExplode/ i want know how start you do with that ??
Byronfilmasl
Blender3D
on Jan 21, 2006 at 12:31:43 am
Hi it me Byron and i just wondering that blender3D can work with Wondertouch for example when first wondertouch any Emitter when finsih can transferring to put add blender3D ? please let me know if it will work or not support that which
Byronfilmasl
IRC
on Jan 24, 2006 at 5:51:46 pm
hello i want know about that IRC wondertouch has use that irc or most time use Forums?? please let me know thank you if not use irc then let me know
