Looping in PI does not work!
COW Forums : Particle Illusion
Klewe1
on Oct 16, 2005 at 10:47:27 pm
Hello there,
I have a problem in looping a film. I used the tutorial on the page and it works fine. The only problem I have is that on the layer 0 I cannot set the sequence to Start: 1 and End: 76. Everytime I put in these settings the computer automatically changes it to: Start: 1 and End: 150.
What I'm I doing wrong?
Please help, I really need the movie I am making.
Thanks alot
Mike
AirWolf
Re: Looping in PI does not work!
on Oct 17, 2005 at 4:54:02 pm
Mine does the same thing but the loop still works for me.
Klewe1
on Oct 17, 2005 at 8:21:01 pm
Mine loops fine in the beginning, but it does the same in the middle of the movie (where I change from one frame to the other) like it did in the beginning when I had no looping at all.
Anny help would be appreciated.
Klewe
Klewe1
on Oct 19, 2005 at 9:25:52 pm
I really need this. Anyone who can help me? Please...
klewe
Alan Lorence
on Oct 19, 2005 at 9:57:45 pm
There is a bug in the Background Image dialog that always shows the "end frame" as the last frame in the sequence. If you change it to a lower value and click OK, the value will be used.
When you open the dialog again, it will show the wrong value, and I think you need to change it again to whatever value you need.
Alan.
wondertouch
Klewe1
on Oct 19, 2005 at 10:28:58 pm
I tried that too, but it keeps not to change right in the middle of the film. When it changes from a layer to the other you see decrease the visibility. At the end (frame 150) it loops fine. What's the matter?
klewe
Alan Lorence
on Oct 19, 2005 at 10:35:47 pm
Make sure you're using the latest version. Check the downloads page for updates.
I'm not seeing the problem that you are, unless I just don't understand it.
Can anybody else duplicate this problem?
Alan.
wondertouch
Klewe1
on Oct 20, 2005 at 7:02:02 am
Here is what I have done:
- Made the video by reducing the number and visibility to zero at the end of the movie. Saved the sequence to pngs.
- then made a new movie creating a new layer (layer 1 below layer 0). Inserted background with parameteres shown in the tutorial.
- the same on layer one.
Should I do something else?
Klewe
