DV Avi as background
COW Forums : Particle Illusion
eyeshine
on Oct 10, 2005 at 4:17:28 pm
"Problem Initalizing avi!" That message is the thorn in my side. Can anyone clearly explain to me what I'm doing wrong with my background image. I am using a DV file as a background and I know PI isn't capable of handling DV yet but I know some of you out there have figured it out. I'm really just learning this system and the only way I have figured out how to use the file is by changing it to an BMP sequence. Is it possible to use the original video? I have downloaded numerous codecs. But maybe I'm not installing them the right way. I don't know!!! Need answers....
Elvis Deane
Re: DV Avi as background
on Oct 10, 2005 at 6:42:24 pm
The "Panasonic DV codec" is the one that everyone has had success with after installing. Once you install it, you should be able to bring in DV avis with no problems.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Medion
on Oct 11, 2005 at 10:10:07 am
You must download the Elisoft codec Pack ,it work
