Waterfall wake
COW Forums : Particle Illusion
AirWolf
Waterfall wake
on Oct 7, 2005 at 12:16:08 pm
I made a nice waterfall animation with pillusion and I was wondering if anybody had suggestions on an emitter to create the wake at the bottom of a waterfall? This is basically the water disturbance at the top surface of a lake or pond as the water comes off the falls and hits the top surface of the body of water below. Thanks for the help!
Alan Lorence
Re: Waterfall wake
on Oct 7, 2005 at 12:58:18 pm
I think you might be able to combine a couple of existing emitters for this. There are a couple of "ocean wave" emitters somewhere... and combine this with the "gurgle" emitter. Will take some adjustments though.
Alan.
wondertouch
Aharon Rabinowitz
Re: Waterfall wake
on Oct 7, 2005 at 1:40:21 pm
What I've done in the past was to create a lot of confined steam at the impact point (A line emitter with low velocity). You might try playin with some of the rain drop emitters by making the area of emission small, and the drops larger with a lower number of drops. Though , the steam has been enough for my needs.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
