pI3 on 64-bit Windows
COW Forums : Boris FX Particle Illusion
Alan Lorence
on Oct 6, 2005 at 11:15:38 am
Is anbody using pI3 on the 64-bit version of Windows? If so, how? (What special settings are needed?)
Thanks.
Alan.
wondertouch
zeeman
Re: pI3 on 64-bit Windows
on Oct 6, 2005 at 1:28:47 pm
Hi Alan,
I am having my computer upgraded with a new motherboard and dual boot (XP Pro and XP64). I should have this done within 2 weeks - I will install my PI 3 for both OS's and inform you of any special requirements then.
Albert
kazesama
on Oct 9, 2005 at 12:52:40 am
No special settings are needed, i've been using version 3 of PI on windows x64 since Beta 1, and it's run perfectly fine. I haven't come into any issues whatsoever.
zeeman
on Oct 11, 2005 at 7:08:48 pm
hi kazesama,
i will be using xp64 shortly. do you use a firewall and antivirus software? i have been holding back as norton antivirus, zone alarm etc are not supposed to be 64 bit compatable. thanks
albert
kazesama
on Oct 12, 2005 at 8:53:59 am
Hi zeeman,
I use Norton Antivirus 10 Corporate Edition. It has a 64-bit version avaliable, and has had so for quite a few months now. It runs fine and I have no issues with it whatsoever.
My router has a built-in hardware firewall. Because of this, I don't bother with anything other than the default windows firewall in terms of a software firewall solution.
Cheers,
Kazesama
