pI3 for OS X update released (3.0.1)
COW Forums : Particle Illusion
Alan Lorence
on Oct 5, 2005 at 10:11:50 pm
If you're a registered owner of particleIllusion 3.0 for OS X, I've released the 3.0.1 update:
Download the update from the following link and run it (make sure particleIllusion is not running first). Then follow the simple instructions to update particleIllusion to 3.0.1. The documentation will be updated as well.
After running the update and verifying that particleIllusion is now 3.0.1 (in the "About particleIllusion" window), you can delete the updater.
One of the new features in 3.0.1 is the Library Manager. It won't look like much when you open it, but you should look at this page in order to make the Library Manager do something useful:
© 2018 All Rights Reserved
