Help with Size of Document and the Output Video in Particle Illusion
COW Forums : particle Illusion
dolfan4life
on Oct 5, 2005 at 1:44:54 pm
I am very confused and fustrated. I would like to use Particle Illusion to create special effects in my filmed movie. The movie is 640X480, so I made the particle illusion document 640X480. Now When go to actions -> save output -> save, it takes me to an output options menu. In the menu there is a column that says OUTPUT SIZE and next to it it says (LIMITED TO STAGE WINDOW SIZE). Under this, it sayz Zoom 100%, and then next to that, the size of the document, which has been CHANGED! It was originally 640X480, now its 456X480. I don't understand. I try adding to the Zoom, but this just adds to the width of the movie, not the height. How can i keep the ORIGINAL SIZE of the file for the actual OUTPUT. Please Help. Thanks.
Alan Lorence
Re: Help with Size of Document and the Output Video in Particle Illusion
on Oct 5, 2005 at 4:30:33 pm
Make your stage window bigger. Either drag the dividers manually, or use the Alt+3 (Cmd+3 on Mac) shortcut to zoom it.
Alan.
wondertouch
