Bug(?) report
COW Forums : Particle Illusion
Diony
Bug(?) report
on Oct 1, 2005 at 9:49:28 am
Deleting the library texture that using by library emitter will crash that library permanently. I suggest that system checks the texture usage and cease the deletion if the result is positive can save my regret...
Alan Lorence
Re: Bug(?) report
on Oct 1, 2005 at 1:02:37 pm
I'll need more details on this crash -- I've deleted library shapes that are being used in the library with no problems before. Perhaps you've found a special case? Please send as much detail as possible to wondertouch support.
Alan.
wondertouch
Diony
Re: Bug(?) report
on Oct 1, 2005 at 1:36:28 pm
To be exact, I deleted the shape in the "emitter properties in library"(right section) and caused the problem. I try again and this time I delete the shape in "emitter properties" of individual emitter (left section), and no error happened, the library emitter simply missed that texture in preview.
