Stays Visible
COW Forums : particle Illusion
Mc Fadge
Stays Visible
on Sep 18, 2005 at 6:18:56 am
Alright so I have a logo that enters the stage but afterwards it fades out due to the emitter I am using. However, I want the image, in this case the logo to stay on the stage and then fade out later or even just add an explosion over it and it disappears. I want to know how I may go about doing this
Elvis Deane
Re: Stays Visible
on Sep 19, 2005 at 10:21:33 am
Is it from one of the logo emitter libraries? You might be able to get it to stay longer just by adjusting the Life property, though it's hard to say without seeing the settings on the emitter.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Aharon Rabinowitz
Re: Stays Visible
on Sep 19, 2005 at 1:20:37 pm
If that fails, you may want to make another emitter with just that particle shape and and make it a "single particle" - This makes the particle live a really long time, and you could then use the visibility property to fade it up and down when you wanted it to disappear.
Just make sure it's in the same place and looks to be the same size as your current emitter's particle shape (the image you want to keep on screen) so it matches up.
You can find the Single Particle option in the emitter properties in the particles tab.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
Mc Fadge
Re: Stays Visible
on Sep 19, 2005 at 8:15:14 pm
Thanks Aharon but the logo becomes brighter when it is in the current emitter. And Elvis the emitter is Eki's "MTV" Style 02 0 if that helps. I tried to find out how to make it fade out by going through the emitter and particle properties but I can't find it. Maybe you could have a look.
Aharon Rabinowitz
Re: Stays Visible
on Sep 19, 2005 at 8:35:40 pm
use the other emitter's visibility property to fade it out as you fade the new one on.
Aharon Rabinowitz
Elvis Deane
Re: Stays Visible
on Sep 19, 2005 at 9:55:11 pm
Okay, that one has keyframes in a lot of places, but it's easy to stretch out it's time on screen.
Basically, it has high Motion Randomness and Velocity settings, which are then animated to go down to 0 at a certain time, causing all those particles to stop going every which way, and stop moving altogether. The reason that the logo fades out is because the Number graph is also animated to stop creating new particles not long after the MoRand and the Velocity shut down. That's what's causing the fade out to happen- no new particles.
So long story short, if you go to the Number graph and move the two keyframes ahead a couple of frames (they are at frame 36 and 37 by default I think), the logo will stay on the screen longer. If you want the wacky movement to go on longer as well, move the keyframes on the MoRand and Velocity graphs ahead too.
Elvis Deane!
