Chroma Key
COW Forums : Particle Illusion
Medion
Chroma Key
on Sep 14, 2005 at 7:26:21 pm
With Which Program did you the Green screen background
(Elvis Deane)Like the tutorial:Distintigrating People?
Mandyy
Re: Chroma Key
on Sep 14, 2005 at 9:11:09 pm
I did mine in Vegas, but Premiere (most high end NLE) has the capability and so does After Effects.
Elvis Deane
Re: Chroma Key
on Sep 14, 2005 at 9:42:58 pm
I used Keylight in After Effects 6.5, but any program that can pull a key and then export the shot with an alpha channel can do the trick. Just make sure when you're exporting the background that you make sure to save it with an alpha channel (in AE for example, you have to set RGB+Alpha in the Output Module, otherwise you just get the RGB with no alpha)
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
