Problem with frames
COW Forums : Particle Illusion
rob3459
Problem with frames
on Sep 10, 2005 at 2:31:45 am
Hi
I am new to Particle Illusion I have inported an AVI that has 902 frames but all I get is 644 frames can someone please tell me why as I have looked at the help and can't find anything
Rob
Alan Lorence
Re: Problem with frames
on Sep 10, 2005 at 11:05:52 am
When you load the AVI, does pIllusion know that it has 902 frames (does "902" show in the layer window)? If so, and you've already made sure that the project end frame (set in the playback toolbar) is 902 at least, then I suggest checking the OpenGL page of the pIllusion prefs, and checking the "don't use texture RAM for bg images" option and see if that helps.
Alan.
wondertouch
rob3459
on Sep 12, 2005 at 12:35:13 pm
Thanks Alan for the help so far.
Yes pIllusion does show "902" frames in the layer window. I did what you suggested in the OpenGL page of the pIllusion prefs,check the "don't use texture RAM for bg images" option But this did not fix it can you suggest anything else ?
Rob3459
Alan Lorence
on Sep 12, 2005 at 3:41:22 pm
Convert the AVI to an image sequence?
Alan.
wondertouch
