Disintegrating people tutorial - stuck, some help please!
COW Forums : Particle Illusion
mandyy
on Sep 9, 2005 at 9:36:21 pm
In the tutorial, Elivis says :
"We'll also change the End box under Sequence/ AVI so that rather than playing for 65 frames, the clip only plays until frame 58. Once we hit Ok and go back to the scene, hitting play will show us the changes."
Where is the END BOX under AVI in the background options panel? I only saw HOLD FRAME, UPPER/LOWER/OFF SEPARATE FIELDS.
I really can't get past this point, because I am unsure of what he meant. Also, when trying to open the project file - it says 'Not a valid PI file', so there is no help there either. any ideas?
I am using PI3.0 on Windows.
Alan Lorence
Re: Disintegrating people tutorial - stuck, some help please!
on Sep 9, 2005 at 9:55:52 pm
You should be using 3.0.1a. Check the wondertouch downloads page.
Alan.
wondertouch
mandyy
on Sep 9, 2005 at 10:12:37 pm
Thanks, I will do that.
Also in the tutorial, is the emitter getting the changes in number or is the particle? Maybe that is where I am going wrong...
