Looping Waterfall at 1024x1024 with minimum frames
COW Forums : Boris FX Particle Illusion
AirWolf
on Sep 3, 2005 at 1:00:23 pm
I trying to create a seamless, looping waterfall at 1024x1024. I've read over the Looping Tutorial under the tutorials sections but I have a problem. I can't produce any more than 150 frames for an animated texture in the game engine I'm working with. The Gurgle emmitter takes so long to start and to go down the entire screen at 1024x1024 that I don't have enough frames of the full waterfall to create looping waterfall. If I double the frames to 300, then the tutorial works but I can't use 300 frames. So does anybody have any suggestions on how I can create a full waterfall at 1024x1024 but with only 150 frames?
Alan Lorence
Re: Looping Waterfall at 1024x1024 with minimum frames
on Sep 3, 2005 at 4:01:37 pm
Render 300 frames but only use every other frame?
Increase the Gurgle emitter's weight (so it falls faster)?
Alan.
wondertouch
AirWolf
on Sep 4, 2005 at 4:05:05 am
That's what I was missing, the weight. It works now. Thanks for the help.
