Can I get an alpha channel with AVI?
COW Forums : Particle Illusion
mandyy
on Aug 20, 2005 at 4:07:02 pm
I was reading about the alpha channel with TGA, but can I get it with a movie file - avi, mpg, mov?
Alan Lorence
Re: Can I get an alpha channel with AVI?
on Aug 20, 2005 at 5:23:54 pm
No, not with AVI. If you're using the Mac version of pIllusion (SE or 3.0) you can create a QuickTime movie with an alpha channel though (if you select a compressor that supports it, and have the number of colors set correctly).
Alan.
wondertouch
Medion
Shake a Clip
on Aug 20, 2005 at 8:10:52 pm
How can a shake a clip like the clip shooty.mov from elvis Deane
with P.I?????
Elvis Deane
Re: Shake a Clip
on Aug 21, 2005 at 2:51:44 am
I did the shaking for that in 3dsmax, just because that enabled me to add the shake to the video clip as well, by bringing my final render from pI, placing it on a plane, and then animating a noisy shake on the camera. The same thing could be done in any 3D program or a compositor, but shaking the video in pI isn't really possible.
But you could use the Offset function to shake the particles in a scene. Just scrub a few frames ahead, click the offset a little bit off to the side of the center, move another two frames, move it to the other side, etc, until a second or two later you place it back to the center of the stage.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
