June Emitter Library released
COW Forums : Particle Illusion
Alan Lorence
on Jul 7, 2005 at 7:25:23 pm
I've finally released the June emitter library. Big thanks to Dan Wilcox for submitting some nice emitters that gave me some inspiration.
Note that this library is larger than many of the others because it uses several largish image sequences. I typically avoid image sequences because I know that large libraries cause more problems, load more slowly, etc.
I think I made some pretty good flame emitters this month. Remember when an emitter name contains "(mb)" it's meant to be viewed with motion blur. If it contains "(mb+)", that means use motion blur, with a higher number of blur frames (like 8 or more).
Re: June Emitter Library released
on Jul 12, 2005 at 2:35:32 pm
WOOWWW!!!! I like them all. ery good library. You can keep the size of the library that high if all the emitter are this quality.
By the way how are done the image sequence used in these emitter?
© 2018 All Rights Reserved
