porblem with emitters in stage window
COW Forums : Boris FX Particle Illusion
jmk
by
on Jun 28, 2005 at 1:34:39 pm
I added emitter to the stage window, then changed tool to select tool. When I want to add another emitter from library window, but I can't. Indicator doesn't change to emitter sign, it shows the pointer sign all along. Is there a way to fix it?
Elvis Deane
Re: porblem with emitters in stage window
on Jun 28, 2005 at 5:48:12 pm
Hit the A key on your keyboard, or click off the little Select arrow icon on the toolbar, and you should be back in Add mode.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
