multi frame shapes ??
COW Forums : Particle Illusion
bam Ross
on Jun 26, 2005 at 10:36:56 am
I HAVE TRIED USING PNG AND PICT SEQUENCES EXPORTED FROM FLASH MX..ONLY 4 OR 5 FRAMES IN LENGTH AND 128 x 128 px .....I CAN ADD THEM TO A LIBRARY OK BUT WHEN I APPLY THEM THE PROGRAMME QUITS>>?????
WHAT AM I DOING WRONG ??
advance in harmony.....BAM
http://www.planetbubble.com
Elvis Deane
Re: multi frame shapes ??
on Jun 26, 2005 at 5:58:34 pm
Strange. If you just add one frame of the sequence, does the program quit too? You may want to try to add them to the emitter but not the library (the button looks the same, it's over to the right of the one that adds them to the library in the Properties window) to see if that also quits.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Alan Lorence
on Jun 26, 2005 at 7:04:18 pm
What version are you using?
Alan.
wondertouch
bam Ross
on Jun 26, 2005 at 8:20:59 pm
I'M USING VERSION 2.0 SE FOR MAC . RUNNING PANTHER ON A DUAL G4 QUICKSILVER W/1.25G RAM
bam Ross
on Jun 30, 2005 at 5:58:29 am
STILL CRASHING EVERYTIME I TRY TO USE MORE THAN A SINGLE FRAME..??
ANY IDEAS...???
THANKS
Alan Lorence
on Jun 30, 2005 at 2:45:55 pm
I have imported a TGA sequence with no problems. Have you tried TGA? How many frames are you trying to import? Have you tried it with just a few (3) images? If it still crashes with 3 images, please send the images to support at wondertouch dot com.
Alan.
wondertouch
bam Ross
on Jul 5, 2005 at 12:35:34 am
AHH HA.......
TGA seems to work fine.........thanks for your help.
bam Ross
on Jun 26, 2005 at 8:18:12 pm
I HAVE TRIED ADDIND IT BOTH WAYS AND IT STILL CRASHES.?
HOWEVER A SINGLE FRAME SHAPE WORKS JUST FINE..
