alpha
COW Forums : Boris FX Particle Illusion
bam Ross
alpha
on Jun 19, 2005 at 7:32:43 pm
what output settings can i use to achieve a transparent back ground.....help...!!
advance in harmony.....BAM
http://www.planetbubble.com
Elvis Deane
Re: alpha
on Jun 19, 2005 at 8:21:09 pm
After you hit the render button, make sure to select a format that supports an alpha channel (PNG, TIF, TGA, and a few others). AVIs out of pI don't export with alpha channels at this time.
Once you've picked a format that alphas will work with, the Save Alpha box should be checkable on the Render Settings page.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
bam Ross
Re: alpha
on Jun 19, 2005 at 8:57:50 pm
does that mean I will have to use an image sequence ?? Is there a way to export an .mov with alpha..??
I've tried exporting as animation with millions of colours + but no luck.
Thanks for the info Elvis
Aharon Rabinowitz
Re: alpha
on Jun 20, 2005 at 12:45:21 am
right now it has to be an image sequence. But if you really need to have a MOV with alpha, you could always import the Tiff, TGA, or PNG sequence into a program like After Effects or a NLE like Vegas, and then output the quicktime with alpha (Straight, not premultiplied).
That's the solution I use. But usually I just use an image sequence - most programs don;t see it any differently than an MOV or AVI.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
bam Ross
Re: alpha
on Jun 20, 2005 at 12:58:51 am
GREAT THANKS AHARON
Alan Lorence
Re: alpha
on Jun 20, 2005 at 2:59:45 am
If you're using pIllusion SE on OS X, then you can save a Movie with alpha. Just make sure you choose a compressor that supports alpha (such as "animation") and make sure you choose the highest number of colors.
Alan.
wondertouch
